Other Projects Tabs shining through scrollbars
Krischu
Post by Krischu » Fri Sep 20, 2019 12:26 pm
Bildschirmfoto 2019-09-20 um 13.23.28.png (367.52 KiB) Viewed 5294 times
macOS 10.14.6
QCad 3.23.0.2 (also in 3.23.0.0)
Is it normal that drawing areas of simultaneously opened projects from other tabs are shining through the scrollbars?
like in the screenshot below:
Christoph
TSG
Re: Other Projects Tabs shining through scrollbars
Post by TSG » Fri Sep 20, 2019 12:52 pm
Definitely not.
But with 3.23.0.2 and macOS 10.14.6 I have much graphic problems so that 3.23.0.2 is not usable for me.
I think, it's because of the new graphics acceleration.
Krischu
Post by Krischu » Fri Sep 20, 2019 1:04 pm
As said, this was with 3.23.0.0 as well aready.
Christoph
Post by Husky » Fri Sep 20, 2019 7:22 pm
Can't reproduce that with Win10.
However - if you find an obvious Bug then a bug report is the fasted way to have it addressed.
Post by andrew » Fri Sep 20, 2019 9:56 pm
It's a Qt / macOS 10.14 bug. There will likely be a workaround for the next release.
