Andrew,
found some trivial typos.
ExMandelbrot.js line 20
> luckily EAction.js will be include by others scripts.
ExMandelbrot.js line 26
> Probably a copy of ExMathSpiral.js
ExMandelbrot.js line 48
ExDumpPolyline.js line 66
> Is Located under Examples/IOExamples/
And one I documented a while ago in a screen grab.
The second example has two closing square brackets.
> The array is [vector1 , vector2 , vector3]
Kind regards
5 trivial typos
5 trivial typos
- Typo addSpline.png (79.94 KiB) Viewed 4126 times
