Would it be possible to have an arc function where if you draw a circle, with lines that intersect it, to choose the centre, then select the intersections of the lines with the circle to define the arc? The same would apply for any intersections of course
Cheers
Centrepoint plus two points arc
- Junior Member
Re: Centrepoint plus two points arc
None of the 10 QCAD Arc tools are working for that scenario? I doubt that but in the case that you actually need to use a circle then you could cut it (Divide tools) at the intersections.
Maybe you can post an example drawing to see the full picture?
