Version 3.21.0
Rantanplan7
Senior Member
Version 3.21.0
Post by Rantanplan7 » Thu Jun 28, 2018 6:52 am
Hi Andrew,
I have just changed to the actual version and have two problems.
The bitmap export from a selection is exporting the whole drawing although there is only a part of it selected.
If I explode a library item to change all lines to dotted lines in red it looks like it should but in the print preview the dotted lines are not dotted anymore. Same with exporting to pdf, the dotted lines are gone.
Best Regards
Sven
(former Autosketch 10 user)
Re: Version 3.21.0
Post by andrew » Thu Jun 28, 2018 9:02 am
Please post separate, unrelated questions into separate topics, thanks.
- attach original drawing files (DXF, DWG, ...) if appropriate
- attach exported files (SVG, PNG, PDF, ...) if appropriate
- include screenshots if appropriate
- if there is an error message, indicate the exact message or include a screenshot of the message
