Angular dimension overshoots
caigner
Post by caigner » Wed Feb 07, 2018 10:06 am
I noticed that the line for angular dimensions is too long when placing the dimension inside.
When placing it outside there is a gap.
Can this be changed in the preferences?
QCAD Pro on Gentoo Linux
Re: Angular dimension overshoots
Post by andrew » Wed Feb 07, 2018 12:17 pm
You might want to select the dimension and move the reference points (blue dots) a bit.
caigner
Post by caigner » Thu Feb 08, 2018 3:14 pm
andrew wrote:You might want to select the dimension and move the reference points (blue dots) a bit.
Ok, that works.
Out of curiosity:
What is the reason for the overhang or the gap?
