Leader Line -Arrow Placement
Clive
Moderator / Drawing Help
Post by Clive » Tue Dec 27, 2016 6:49 pm
For me I would like to request an option to be able to use the leader line tool (dimension toolset) and place the arrow/tick at the end of my line if I choose to rather than place arrows first. Is this easily doable with the current leader tool?
hungerburg
Re: Leader Line -Arrow Placement
Post by hungerburg » Wed Dec 28, 2016 11:46 am
Autodesk documentation says, arrowhead is a boolean attribute. I thought, you would just have do "modify, reverse", but "R V" does not work on leaders, should it? A workaround is to "F H, F V" mirror twice.
