One click corner fillet (a la Aspire)
artisanicview
Post by artisanicview » Fri Jun 03, 2016 10:48 am
I need to make a lot of fillets to the corners of the shapes that I have in my drawing, and because I need to make this daily a lot of times I want to know if it is possible to have a simpler way to do the corner fillets in Qcad? Instead of using two clicks I will appreciate to have only ONE click fillet like in the Vectric Aspire. I uploaded a video who is demonstrating how it is made a corner fillet in Aspire vs the same corner fillet in Qcad.
Corner Fillet
Re: One click corner fillet (a la Aspire)
Post by andrew » Fri Jun 03, 2016 12:59 pm
artisanicview
Post by artisanicview » Thu Jan 26, 2017 1:38 pm
Bumpy bump. Has passed some time and still I'm waiting to see this feature integrated into QCAD. Any chance to have-it please?
Or even better, make a fillet straight from two parallel lines, so no need to make two separate fillets between the lines united by 90 deg., but just one click and have a nice fillet between the two parallel lines (180 deg.). This will make my work a lot more easier than it is now.
