Hello QCAD Developers and Community,
After thorough exploration, it has come to my attention that QCAD cannot currently adjust the number of decimals after the point when incorporating area measurements. Specifically, when dealing with measures in the metric system, I've encountered challenges due to the absence of a feature allowing users to set the desired decimal precision.
In light of this, I propose implementing a feature that enables users to configure the number of decimals in area measurements. Such an addition would significantly enhance the precision and flexibility of QCAD, particularly for those engaged in projects that demand meticulous attention to detail.
I appreciate your consideration of this feature request and look forward to potential improvements in future updates.
Best regards,
Kmeelo.
Feature Request: Decimal Precision Control in QCAD
- XN-231126-12-12.jpg (439.72 KiB) Viewed 3719 times
Re: Feature Request: Decimal Precision Control in QCAD
I filed a feature request on your behalf:
https://qcad.org/bugtracker/index.php?d ... sk_id=2505
Feature request or bugs addressed on the forum may loose focus after a while.
The QCAD Suggestions and Feedback is rather a place to openly discuss suggestions or to give feedback.
CVH wrote: ↑Sun Nov 26, 2023 11:17 pmHi,
Thank you!
