[solved] Search the QCAD E-book
Could it be possible to add a search feature to the e-book?
Re: Search the QCAD E-book
The QCAD E-Book is a PDF file and can be searched using your PDF viewer (e.g. Acrobat Reader or your system's built in PDF viewer).
OK. I see it now under edit.
Thank you.
Thank you.
