[Solved] Uncaught exception ConvertUnit.js
Post by CVH » Tue Aug 30, 2022 7:43 am
Andrew,
With the intention to add US survey units ...
I get an error that I can't place when running Convert.js in debug mode.
Allready converting from mm to inch the code stumbles on:
156  var s = entity.getDimscale(false);
Uncaught exception at scripts/Edit/ConvertUnit/ConvertUnit.js:156: Error: : -1: -1: Wrong number/types of arguments for RDimensionEntity.getDimscale().
<native>(false) at -1
<anonymous>(di = RDocumentInterface(0x128a13c8), fromUnit = 4, toUnit = 1) at scripts/Edit/ConvertUnit/ConvertUnit.js:156
<anonymous>() at scripts/Edit/ConvertUnit/ConvertUnit.js:58
<anonymous>(false) at scripts/Edit/ConvertUnit/ConvertUnit.js:250
<global>() at -1
Has it something to do with the recent change to dimStyle ?
Re: Uncaught exception ConvertUnit.js
Post by andrew » Tue Aug 30, 2022 8:12 am
What version are you on?
Line 156 does not seem to match with the current version:
https://github.com/qcad/qcad/blob/v3.27 ... ertUnit.js
[Solved]: Uncaught exception ConvertUnit.js
Post by CVH » Tue Aug 30, 2022 4:51 pm
Seems to be a mix .... 3.27.0 and bits and pieces ...
Even with a new copy of the script in question it halts now on line 162 ...
I think it is time that I update QCAD completely and also download the latest master from GitHub as reference.
Sorry about not looking deeper for the obvious cause.
