changing icon
bakoun
changing icon
Post by bakoun » Wed Jul 06, 2022 8:45 am
Hi !
I wrote a small script that shows/hides a specific layer.
I would like the button icon to change depending on the state of the layer. For example: ToggleSpitLayer.svg when the layer is visible and ToggleSpitLayer-off.svg when it is not.
include("scripts/Layer/Layer.js");
function ToggleSpitLayer(guiAction) {
    Layer.call(this, guiAction);
ToggleSpitLayer.prototype = new Layer();
ToggleSpitLayer.init = function(basePath) {
	var action = new RGuiAction(qsTr("Show/Hide Spit layer"), RMainWindowQt.getMainWindow());
    action.setScriptFile(basePath + "/ToggleSpitLayer.js");
	action.setIcon(basePath + "/ToggleSpitLayer.svg");
	action.setStatusTip(qsTr("Show/Hide Spit layer"));
    action.setDefaultShortcut(new QKeySequence("s,p,i"));
    action.setDefaultCommands(["spi"]);
    action.setGroupSortOrder(80100);
    action.setSortOrder(300);
    action.setWidgetNames(["MenuSpit", "ToolBarSpit"]);
ToggleSpitLayer.prototype.togglevue = function(layerName, operation) {
	try {
		var layer = this.getDocument().queryLayer(layerName);
		layer.setFrozen(!layer.isOff());
		layer.setOff(!layer.isOff());
		operation.addObject(layer);
	}catch(error){}
ToggleSpitLayer.prototype.beginEvent = function() {
    Layer.prototype.beginEvent.call(this);
	var operation = new RModifyObjectsOperation();
	this.togglevue("SPIT", operation);
    di.applyOperation(operation);
	this.terminate();
Any ideas?
Thanks in advance!
Re: changing icon
Post by andrew » Wed Jul 06, 2022 12:31 pm
You can retrieve your action (RGuiAction, inherited from QAction) from anywhere with:
var action = RGuiAction.getByScriptFile("scripts/......./ToggleSpitLayer/ToggleSpitLayer.js");
You can then change the icon with:
action.setIcon(...);
bakoun
Re: changing icon
Post by bakoun » Wed Jul 06, 2022 2:04 pm
Many thanks !!!
Re: changing icon
Post by CVH » Thu Jul 07, 2022 4:26 am
Note that the KeySequence ("s,p,i") would conflict with Draw Spline (Control Points) with KeySequence("s,p"). :wink:
