Getting handle inside start or end Transaction()?
bob
Post by bob » Wed Jun 15, 2022 7:32 pm
This works and prints out
entities:
riser: 59
line: 60
However if I surround addLine() with start/endTransaction() the line handle is -1. Why is that? Can I not surround these draw functions with that? Should I? How to get handles if you do that?
Bob
	entities = {};
	closed = true;
	relative = false;
	var obj = addPolyline(points, closed, relative);
	print('polyline handle = ' + obj.getHandle());
	entities['riser'] = obj.getHandle();
	// startTransaction(di);
	obj = addLine(0,0, 50,50);
	// endTransaction()
	print('line handle = ' + obj.getHandle());
	entities['line'] = obj.getHandle();
	print('\nentities:');
	// print(entities);
	for (var key in entities) {
		print(key + ':   ' + entities[key]);
Re: Getting handle inside start or end Transaction()?
Post by CVH » Thu Jun 16, 2022 4:30 am
Newly added entities or objects do not yet have a valid ID if they were added within a transaction.
(We will look that up in a minute)
They are only created in group at the end of the transaction.
Yes you could, but only useful with a group of actions.
Every action is followed by a screen update and much more than that :wink:
With a grouped transaction just one update instead of one each action.
You need to re-query the entity(ies)/object(s).
The simplified API of QCAD is intended to do basic things in an easy way.
I think you may want to get deeper into scripting under QCAD :wink:
A reference of the open source: https://qcad.org/doc/qcad/3.0/developer/annotated.html
Scripts can be found on GitHub: https://github.com/qcad/qcad
About ID=-1 ... simple.js : https://github.com/qcad/qcad/blob/087f4 ... _create.js
- function addPolyline(points, closed, relative) creates a polyline shape called pl and returns addShape(pl).
- function addShape(shape, color, linetype, lineweight) creates a polyline entity for the document and returns addEntity(entity).
In the above we have the first remark on IDs within transactions :| (Also: https://qcad.org/doc/qcad/3.0/developer ... ba88080a01)
- function addEntity(entity) returns addObject(entity) and that will add the object and return a reference to it.
Further mind that the ID and the handle is not the same but you can get the handle by the entity ID at runtime.
There are numerous examples of scripts in the GitHub repository :wink:
Post by andrew » Thu Jun 16, 2022 10:06 am
To get the handle of the objects added by a transaction, you'd have to re-query the object after adding it or inspect the transaction, for example:
transaction = endTransaction();
var ids = transaction.getAffectedObjects();
for (var i=0; i<ids.length; ++i) {
    var id = ids[i];
    var entity = document.queryEntity(id);
