Can you name an entity?
bob
Post by bob » Wed Jun 15, 2022 5:54 pm
I can create entities with a script and see them. Using queryAllEntities I can list them. Is it possible to give them names so that they can be referred to that way later in the script? Or should I be thinking about blocks? I haven't yet found a way to create blocks (of entities) programmatically.
Bob
Re: Can you name an entity?
Post by andrew » Wed Jun 15, 2022 5:59 pm
You can use the entity handle to reference entities. The handle is persistent, even when saving to DXF/DWG and later loading from DXF/DWG again.
entity.getHandle()
