My First Script
bob
My First Script
Post by bob » Tue Jun 14, 2022 5:21 pm
Ubuntu 20.04 running qcad-3.27.6-trial-linux-x86_64
The javascript works if I run the script after starting qcad ("Misc/Development/Run Script"). I have some questions about this.
1. Where is the documentaion or declaration is for qWarning?
2. I've read that you should include simple.js. Is that no longer required?
3. Layer '0' still shows up. Can I rename '0' to 'main' or delete layer '0'?
qWarning('hello');
var document = this.getDocument();
addLayer('main');
addLayer('dimensions');
di.setCurrentLayer('main');
di.setCurrentColor(new RColor(255, 0, 0));
points = [
   [0, 0],
   [40, 0],
   [40, 40],
   [0, 40],
closed = true
relative = false
addPolyline(points, closed, relative)
autoZoom();
Thanks,
Bob
Re: My First Script
Post by andrew » Tue Jun 14, 2022 5:54 pm
It's part of the Qt API. It prints to stderr.
When running a script through the GUI, chances are that "Simple.js" has already been included somewhere else. I'd still recommend to include it in your script to make sure it's included at least once.
No. Layer '0' is part of the DXF/DWG standard and cannot be deleted or renamed.
bob
Re: My First Script
Post by bob » Tue Jun 14, 2022 6:12 pm
Thank you
