[solved] SvgExporterPG loosing colors
sperez
Post by sperez » Wed Mar 23, 2022 11:10 pm
We are devoloping an ecmascript to export with the QCAD Pro (version 3.23.0.0 ) script SvgExporterPG
   include("scripts/Pro/ImportExport/SvgExporter/SvgExporterPG.js");
    var nomsvg = "/tmp/outputfile.svg";
    var exporter = new SvgExporterPG(doc, {});
    exporter.exportFile(nomsvg);
All the entities exported has the color with the svg node attribute with a value of fill:#a44646 but in the dxf file thiis not the color asigned. Is it possible to asign the true color in the svg exported file ? Maybe the constructor has options that I don't know
Thanks in advance
Re: SvgExporterPG loosing colors
Post by andrew » Thu Mar 24, 2022 7:31 am
Please indicate your operating system and attach the drawing files in question.
sperez
Post by sperez » Sat Mar 26, 2022 9:00 pm
Sorry It was my mistake I had developed a script that modify some properties and after somes remove operations finally the initial file was converted with that error.
Thanks and sorry again .
