MouseMove listener
RR88
MouseMove listener
Post by RR88 » Fri Oct 01, 2021 5:10 pm
Hello.
I want to get the mouse-position within a document. How can I do this? I tried this:
include('scripts/EAction.js');
function Test(guiAction) {
    EAction.call(this, guiAction);
Test.prototype = new EAction();
Test.prototype.beginEvent = function() {
    EAction.prototype.beginEvent.call(this);
Test.prototype.mouseMoveEvent = function(event) {
    qDebug(event.getScreenPosition());
Test.init = function(basePath) {
    var action = new RGuiAction('Test', RMainWindowQt.getMainWindow());
    action.setGroupSortOrder(100000);
    action.setSortOrder(0);
    action.setWidgetNames(['MiscModifyMenu']);
mouseMoveEvent will not be called.
Arch Linux, QCad 3.22.0 Prof.
Re: MouseMove listener
Post by andrew » Fri Oct 01, 2021 5:21 pm
Your menu does not actually call a script (or do anything at all).
Add this to your Test.init:
action.setScriptFile(basePath + "/Test.js");
To learn how to do these things properly, please browse the examples at:
https://github.com/qcad/qcad/tree/master/scripts
For example the point drawing tool at:
https://github.com/qcad/qcad/tree/maste ... nt/Point1P
RR88
Post by RR88 » Fri Oct 01, 2021 5:25 pm
Thanks. I knew I had forgotten something. :D
