Dwg Import Library
davecoventry
Dwg Import Library
Post by davecoventry » Fri Jul 30, 2021 9:15 am
Does QCAD use the libredwg dwg import library?
The reason I ask is that I am getting fatal errors when I use the libredwg dwg2dxf, yet QCAD opens the drawing without issue.
Re: Dwg Import Library
Post by CVH » Fri Jul 30, 2021 9:26 am
I think you may want to include in what dwg version that those drawings are ... :wink:
Post by andrew » Fri Jul 30, 2021 9:55 am
QCAD uses the OpenDesign libraries.
davecoventry
Post by davecoventry » Sat Jul 31, 2021 6:58 am
Version number AC2027.
Thanks, Andrew: that makes sense.
Libredwg handled other drawings of the same version (sent from the same source). I was just a little surprised when QCAD opened it without issue.
