Hide entities
sinase
Hide entities
Post by sinase » Wed Jun 30, 2021 11:18 am
Is there any way to select and delete hide entities that it not to belong to contour?
To detect duplicates doesn't work for that and, if i try to select contour (double click), these entities are selected too.
Many thanks.
Re: Hide entities
Post by andrew » Wed Jun 30, 2021 11:42 am
You'd have to program an algorithm for that (i.e. iterate through those entities, find overlapping entities, decide which ones to delete, etc.).
sinase
Re: Hide entities
Post by sinase » Fri Jul 02, 2021 8:43 am
Overlapping is not an entity attribute, isn`t it?
If i could return those entities overlapping each other and select the one whose length is less.
Regards.
Re: Hide entities
Post by CVH » Fri Jul 02, 2021 10:00 am
No, it isn't implemented. :(
https://qcad.org/doc/qcad/3.0/developer/annotated.html
With a collection of entities sorted from shortest to longest.
Cycling all from shortest to longest:
For Line segments, being overlapped would mean:
Line X(0-n) his start or endpoint sits on any other longer entity.
AND
The orientation is the same or opposite as that of the longer entity.
Line segments can be overlapped by XLines ... Rays ... Polylines ... (Even by Ellipses & Splines :roll: )
For Arc segments something similar but then with start/end/radius/center.
Arcs can be overlapped by Circles ... Polylines ... (Again also by Ellipses & Splines :roll: )
A certain tolerance would be required too. :wink:
Then diversify in:
  • Connected
    Partially overlapped
    Fully overlapped
Just thinking out loud. :lol:
