Odd self intersection points
Post by CVH » Wed Jun 16, 2021 10:24 pm
Andrew,
How comes ...
Included a dxf with 2 polylines in different scales.
Odd-Self-Intersections.dxf
(121.26 KiB) Downloaded 474 times
I marked the self-intersection vectors returned by:
var points = polyline.getSelfIntersectionPoints();
How comes that .getSelfIntersectionPoints returns actual singular vertices of a polyline :?: :!:
First, presumed it was the minute scale of things, the smallest are actually 10x the originals.
Scaling up, there are even more singular vertices considered self-intersecting ... :shock:
Is there a function that can subtract a vertices array from the .getSelfIntersectionPoints array?
Re: Odd self intersection points
Post by andrew » Thu Jun 17, 2021 4:56 pm
This is very likely a tolerance issue (since there are arc segments involved). I will add a tolerance parameter for the next update.
Post by CVH » Thu Jun 17, 2021 8:21 pm
Ok, thanks.
Yes, bulging is involved as these are explosions of splines.
Snippets of the Eagle shape here:
https://qcad.org/rsforum/viewtopic.php? ... gle#p24417
Just any of the many shapes I use to lauch trial maths on. :wink:
- RoundCorners
- Pocketing
Post by CVH » Sat Jun 19, 2021 11:01 am
Andrew,
https://github.com/qcad/qcad/commit/930 ... bb1274ddc9
For polylines form splines ... What are tangentially connected segments.
Catching almost all false positive nodes with 2e-8 tolerance ... :wink:
None with 1e-9 = RS.PointTolerance.
Depends a little on how far they sit from the origin >>> Larger 1ULP.
And on how good the polar representation of an arc endpoints can be.
While the Cartesian position changes, the bulging factor is equal and rather small here.
Another oddity is that nodes and endpoints of shapes from such a polyline
only differ in the range 3e-12 -- 5e-11 :shock: (node vs ends & end vs end)
Still, a tolerance gap of factor 2000 -10.000 ... One that I can't explain :?: :!:
Post by CVH » Sun Jul 18, 2021 11:23 am
Andrew, All,
Based on a wide survey ... (0 ... 10,000,000)
Filtering all false positives from an RPolyline.getSelfIntersectionPoints() list ...
Including for troublesome bulging polylines ...
Ignoring the bulge factors to arc shapes floating point uncertanties ...
But simply based on the largest absolute X or Y value of a box surrounding the polyline ...
var box = entity.getBoundingBox();
var maxNumber = Math.max(Math.abs(box.c1.x), Math.abs(box.c1.y), Math.abs(box.c2.x), Math.abs(box.c2.y));
var tolerance = 4.00e-9 * Math.pow(maxNumber, 0.45);
# Edited # Forgot a safety margin ... :oops:
This is based on the equation of a trend line of filtered results without false positives.
One may remark that:
- 4.00e-9 is 4x RS.PointTolerance.
- To power 0.45 is almost the root.
Bottom line: The required tolerance value is governed by the Floating Point uncertainty of the coordinate values.
