document layers seem to be missing after passing to function
ScottP
Post by ScottP » Tue Mar 30, 2021 11:30 pm
I'm probably I'm missing something obvious here...
I'm making an RDocument from a DXF file,
inputfile
, that has multiple entities on multiple layers.
I then duplicate the document, intending to selectively change some of the entities/layers, but when I pass the duplicated document's reference to a function, the number of layers changes. :?
//SETUP DOCUMENT
var storage = new RMemoryStorage();
var spatialIndex = new RSpatialIndexSimple();
var doc = new RDocument(storage, spatialIndex);
var di = new RDocumentInterface(doc);
if (di.importFile(inputFile) != RDocumentInterface.IoErrorNoError) {
	qWarning("Cannot import file:", inputFile);
	di.destroy();
        return;
//DUPLICATE DOCUMENT
var storageTemp = new RMemoryStorage();
var spatialIndexTemp = new RSpatialIndexSimple();
var docTemp = new RDocument(storageTemp, spatialIndexTemp);
var diTemp = new RDocumentInterface(docTemp);
doc.selectAllEntities();
var co = new RCopyOperation(new RVector(0,0), doc);
diTemp.applyOperation(co);
//TRY
debugger;
var layerIDsCheck = doc.queryAllLayers();
var layerIDsTempCheck = docTemp.queryAllLayers();
//Here, I get exactly the same hex values for doc and docTemp, and for layerIDsCheck and layerIDsTempCheck (5 elements each)
var layerIDs = getSortedLayerIDs(docTemp);
function getSortedLayerIDs(docu){
	var layerIDs = docu.queryAllLayers();
	//For me, docu does not have the same hex value as docTemp did, and layerIDs now holds 3 elements with values differing from those in layerIDsCheck and layerIDsTempCheck
The DXF I'm using has thousands of entities. If I reduce the DXF to only arc entities, for example, then in passing to
getSortedLayerIDs()
, the IDs still change but the number of layers is maintained (might be some coincidence).
QCAD version: 3.26.1.0
Date: Mar 8 2021
Qt version: 5.13.2
Compiler version: MSVC++ 14.0 (2015)
Build date: Mar 8 2021
Revision: eec8166e891241909e2a1821e3bf9e3dd0aa2366
Architecture: x86_64
OS: Win10
Thank you for any help!
Re: document layers seem to be missing after passing to function
Post by andrew » Wed Mar 31, 2021 7:20 am
RCopyOperation copies all selected entities across. Layers are copied as needed. I.e. layer "X" is copied if one of the selected entities is on layer "X".
You can use co.setCopyAllLayers(true) to always copy all layers.
