[SOLVED] RLayer setColor
sinase
Post by sinase » Thu Mar 18, 2021 11:44 am
There is any example to change the current layer color by script code?
I have seen the module RLayer --> setColor but i don't know how his use is.
Re: RLayer setColor
Post by andrew » Thu Mar 18, 2021 12:55 pm
You can find an example script that changes the color of a layer at:
viewtopic.php?f=32&t=6008&p=22580#p22580
The ID of the current layer can be queried as:
var id = document.getCurrentLayerId();
sinase
Re: RLayer setColor
Post by sinase » Thu Mar 18, 2021 4:47 pm
Thank you Andrew,
var document = this.getDocument();
var layer = document.queryLayer(id);
layer.setColor(new RColor("#ff0000"));
op.addObject(layer);
di.applyOperation(op);
This code works for my application.
Regards.
