[Solved] Layer scripting
pogocad
Post by pogocad » Mon Mar 15, 2021 8:16 am
I changed my background from black to white. Unfortunately some layer colors are now hard to see on the white background. So I am looking for a scripting example to alter the layer colors for my existinng drawings. Or does anyone know an easier way?
Regards
QCAD Professional
Version: 3.26.1.0 (3.26.1)
Build Date: Mar 8 2021
Revision: eec8166
Qt Version: 5.13.2
Architecture: x86_64
petevick
Re: Layer scripting
Post by petevick » Mon Mar 15, 2021 8:33 am
would the Color Adjustment setting help you in Application Preferences>Graphics View>Appearance :?:
Pete Vickerstaff
Re: Layer scripting
Post by CVH » Mon Mar 15, 2021 8:38 am
for an example of a script that alters layer colors see the 'all in one' variant here:
https://qcad.org/rsforum/viewtopic.php?t=7865
This script has two stages as required by the user in the topic.
The first RModifyObjectsOperation changes any layer with 'whiteColor' to 'blackColor'
In your case that might test for more colors.
Color names or RGB values, names are SVG names ... CAD "green" = "lime" ...
pogocad
Re: Layer scripting
Post by pogocad » Tue Mar 16, 2021 11:20 am
Hi
thanks for the hint. The first part of the script does what i looking for.
Regards
