[solved]Saving the state of widgets in Options toolbar
petevick
Post by petevick » Mon Mar 08, 2021 9:07 pm
In the PolyLineBreakSymbol ui (named changed to stop conflict with LineBreakSymbol ) I have a checkbox, a spinbox and a pair of radiobuttons in the ui of Options toolbar, when I exit the tool, the state of the radiobuttons is not being saved, the checkbox and spinbox states are being saved. I've deleted the PolyLineBreakSymbol section in Qcad3.conf, and on restarting Qcad, the state of the radiobuttons is saved only once, ie I start PolyLineBreakSymbol, draw a break, exit the tool, restart the tool, radiobutton state was saved, change the state, draw a break and exit the tool, the next time I start the tool the radiobutton state is not as the previous session.
I think it's a Linux thing as I've tried it in Windows (running under Wine) and the radiobutton states are saved every time.
Pete Vickerstaff
Re: Saving the state of widgets in Options toolbar
Post by andrew » Mon Mar 08, 2021 9:23 pm
Can you try putting the radio buttons into a button group:
1. Select both radio buttons
2. Right-click on one of them and choose
Assign to button group > New button group
You also might want to give the button group a meaningful name. Make sure that the button group is set to "exclusive", so only one of the radio buttons can be checked.
petevick
Post by petevick » Mon Mar 08, 2021 9:26 pm
Thanks Andrew, I'll get on to it. :wink:
Pete Vickerstaff
Post by CVH » Mon Mar 08, 2021 9:28 pm
Pete,
In a qcad.ini it looks like it is stored fine.
Exclusive QRadiobutoons are stored in bulk.
The name of checked one is stored. :wink:
[PLineBreakSymbol]
VisibleInMenu=true
VisibleInToolBar=true
VisibleInCadToolBar=true
VisibleInMatrixPanel=true
RemoveSegment=true
BreakHeight=3
IncSeg=IncSeg
petevick
Post by petevick » Mon Mar 08, 2021 9:34 pm
I love quick fixes. That did the job, thanks Andrew
Pete Vickerstaff
