I'm expanding my LineBreakSymbol script to include three options in the options toolbar, a checkbox, a spinbox and a pair of radiobuttons. I'm communicating with the ui using the .prototype.slot<....>Changed = function(value) method. I've taken the method from BreakOutManual.js, and based the ui on BreakOutManual.ui but I am unable to get the script to communicate with the ui to update the variables. I also followed the guidance here -> https://qcad.org/en/tutorial-interactive-script-actions and particularly the Adding Widgets to the Options Toolbar section.
I just can't see what I'm doing wrong. script and ui attached. Please help, brain is aching !!
[solved]Problem with script communicating with ui
- petevick
- Premier Member
- LineBreakSymbol.zip
- (2.95 KiB) Downloaded 328 times
Pete Vickerstaff
Re: Problem with script communicating with ui
It's the order of things:
The last line here overwrites and essentially removes those methods defined above it.
Make sure that
is directly after the constructor function, before attaching any functions to it:
LineBreakSymbol.prototype.slotRemoveSegmentChanged = function(value) {
this.removeSegment = value;
LineBreakSymbol.prototype.slotBreakHeightChanged = function(value) {
this.breakHeight = value;
this.updatePreview(true);
LineBreakSymbol.prototype.slotIncSegChanged = function(value) {
this.incSeg = value;
LineBreakSymbol.prototype = new EAction();
Make sure that
// constructor:
function LineBreakSymbol(guiAction) {...}
// inheritance (defining the prototype):
// methods (attaching functions to prototype):
LineBreakSymbol.prototype.myFunction1 = function(...) {...}
LineBreakSymbol.prototype.myFunction2 = function(...) {...}
- petevick
- Premier Member
Thanks for the reply Andrew. I've tried moving the LineBreakSymbol.prototype = new EAction(); to after the function LineBreakSymbol(guiAction) {}, followed by the three .prototype.slot<....>Changed = function(value), but then the script hangs in Qcad.
Pete Vickerstaff
If you look at the output in the terminal from which you are starting QCAD, you can see the exception caused by the script:
You might want to check if this.startpt is defined at the start of getOperation and return undefined if not.
script engine exception: "TypeError: Result of expression 'this.startpt' [undefined] is not an object."
Warning: "<anonymous>(preview = true) at scripts/Misc/MiscDraw/LineBreakSymbol/LineBreakSymbol.js:143\n<anonymous>(clear = true) at /Users/andrew/data/RibbonSoft/projects/QCAD3/qcad/scripts/EAction.js:1714\n<anonymous>(value = 1) at scripts/Misc/MiscDraw/LineBreakSymbol/LineBreakSymbol.js:53\n<anonymous>(widget = QToolBar, group = 'LineBreakSymbol', signalReceiver = RActionAdapter(0x7fa359c8b600)) at /Users/andrew/data/RibbonSoft/projects/QCAD3/qcad/scripts/WidgetFactory.js:830\n<anonymous>(resume = false) at /Users/andrew/data/RibbonSoft/projects/QCAD3/qcad/scripts/EAction.js:409\n<anonymous>() at /Users/andrew/data/RibbonSoft/projects/QCAD3/qcad/scripts/EAction.js:99\n<anonymous>() at scripts/Misc/MiscDraw/LineBreakSymbol/LineBreakSymbol.js:66\n<native>(RActionAdapter(0x7fa359c8b600)) at -1\n<global>() at 1"
if (!isVector(this.startpt)) {
return undefined;
- petevick
- Premier Member
Thanks Andrew, I'll take a look.
Pete Vickerstaff
- petevick
- Premier Member
Thanks Andrew, again, all working now
Pete Vickerstaff
