ECMA script. Read .txt file content
sinase
Post by sinase » Thu Mar 04, 2021 8:12 am
I have a new .dxf open and i like to export it a .dxf file by ECMA script, with the name of .txt file content. Is it possible do this by programming? For example, if i write on my .txt the word "helloworld", my .dxf exported will be helloworld.dxf.
//Begin
var action2 = RGuiAction.getByScriptFile("scripts/File/NewFile/NewFile.js");
if (!isNull(action2)) {
action2.slotTrigger();
var di = EAction.getDocumentInterface();
var document = di.getDocument();
* I need to read .txt file content and save in "data" variable. This .txt would be in a local path of my computer.
di.exportFile("/Users/jchueca/Desktop/" + data + ".dxf", "DXF 2000");
//End
Thank you very much.
Re: ECMA script. Read .txt file content
Post by andrew » Thu Mar 04, 2021 8:32 am
You can read the contents of a file into a string variable using this convenience function:
include("scripts/library.js");
var str = readTextFile("/path/to/file.txt");
If the file cannot be found or cannot be read, undefined is returned.
Note that the file might contain line feed which will also be read and returned.
Post by CVH » Thu Mar 04, 2021 8:55 am
To read text I was thinking of a QTextStream ...
And that is exactly what readTextFile() from library.js does.
it reads a full text file: var contents = textStream.readAll();
If the file holds multiple entries you could also cycle trough it line by line.
var textLine = textStream.readLine();
Two simple examples:
..QCAD\scripts\Misc\Examples\IOExamples\ExRegisterFileImporter\ExRegisterFileImporter.js
..QCAD\scripts\Misc\MiscIO\ImportPoints\ImportPoints.js
Or you source them from Github.
Both under:
https://github.com/qcad/qcad/tree/master/scripts/Misc
sinase
Post by sinase » Thu Mar 04, 2021 9:17 am
readTextFile() helped me.
Thanks!
