[SOLVED] How To: Suspend AutoSave by script
Post by CVH » Mon Nov 30, 2020 5:23 am
Andrew,
Is there a way to suspend AutoSave by script?
Tried to follow the AutoSave.js script ... had to include it
include("scripts/File/AutoSave/AutoSave.js")
Still the methods report 'undefined'
Re: How To: Suspend AutoSave by script
Post by andrew » Wed Dec 16, 2020 2:31 pm
You can control this through a global application wide property:
var appWin = EAction.getMainWindow();
appWin.setProperty("DisableAutoSave", true);
appWin.setProperty("DisableAutoSave", false);
Post by CVH » Thu Dec 17, 2020 8:57 am
Thanks, Andrew.
Now implemented in the 'Create New subLayers from Hatches' proposition ...
And working! :D
Stumble on it while testing ... and it was reported by someone else too.
When a drawing is hard to render ...
or when a script runs slow on such a drawing ...
and AutoSave is set and to frequent short intervals ...
QCAD is spending even more time in auto saving the drawing over and over again.
