How To: non-visible blocks
Post by CVH » Wed Nov 25, 2020 9:26 am
I was lurking in the CAM section.
viewtopic.php?f=74&t=7809
Loaded both Router-Vac-Mount.02.dxf in QCAD
Installed QCADCAM trial
Loaded them again
I can't figure out the Blocks setup in those files.
I can edit unlisted blocks.
I see entities one above the other. (mixed color red-white with one selected)
I can select them with the Alt key (some not) and most things I get make sence.
I can read the dxf directly and see that some unlisted blocks have attributes that have a meaning in CAM.
Question:
How to create such unlisted blocks to store relevant data used in Tile2Hatch.
Currently I use layer or Entity custom attributes.
The issue is that I can't protect such information.
The user can alter these entities or custom attributes and then they are no longer in sync.
Re: How To: non-visible blocks
Post by andrew » Mon Nov 30, 2020 8:13 am
These blocks are hidden from the user if
Edit > Application Preferences > Widgets > Block List > Hide internal blocks
is checked.
The relevant custom property is:
ResourceFlag
If this property is set (to any value), the block is considered a QCAD internal resource block. These are used to represent tools and toolpaths in QCAD/CAM and can be used to represent any other custom objects in other QCAD extensions.
See also:
https://github.com/qcad/qcad/blob/maste ... st.js#L156
Post by CVH » Mon Nov 30, 2020 8:51 am
Thanks,
I see, and anonymous blocks (A$C+10chars) too.
You mention 'to any value' ... Is there a guide, a ruling, a list?
Good to know.
Although that isn't the end of the story ...
This means I have to merge my system entities in a block ... :oops: by script.
Up to now I have not much experience with those.
Kinda avoided them being rather buggy at some few points.
(That is my point of view reading all topics and bug reports :wink: )
