[SOLVED] framework version
Post by CVH » Fri Oct 23, 2020 8:29 am
Andrew,
To extract an orphanated hatch pattern Tile2Hatch has to check the QCAD framework being 3.25.2.1 or later.
What is best practice?
RSettings.getNumericalVersionString()
- Application version as 01020304 for 1.2.3.4
RSettings.getIntValue("Application/Version", 0)
- Stored Application version from QCAD.ini as 01020304 for 1.2.3.4
I asume the leading zero is a typo for a Number type. :wink:
The other option is library.js
Why does requiresFramework uses 3 digits per section?
What to pass here as maxVersion array if a maximum is not defined?
Re: framework version
Post by andrew » Mon Oct 26, 2020 3:13 pm
I'd use:
if (RSettings.getCurrentVersion()>=3250201) {
Post by CVH » Mon Oct 26, 2020 6:00 pm
Thanks for the advise ...
All where prepared, used the isSmaler variant to rule thing out.
An lazy edit later .... 8)
