Script file encoding
Post by CVH » Sun Mar 22, 2020 11:33 pm
Interesting to know, also seen some related topics and other less related as the multi line command pasting.
viewtopic.php?f=89&t=7077#p27256
The problem in this topic was the umlaut sign is encoded different in ANSI.
Qcad reads the script as if it is encoded in UTF-8.
Could also be the reason that some of my coding fails at specific points.
Getting my own code back by a fresh install it seems no longer to be an issue....
Developing further the same issues popped up.
Next effort I will enforce NPP to use UTF-8 and see where that brings us.
Avoiding UTF-8 BOM because the BOM is again a windows thing.
CVH.
