Hello
I can't change the color of an entity made with QCAD Simple API
I did some tests (see around line 662 of the attached code) also taking inspiration from https://qcad.org/rsforum/viewtopic.php? ... olor#p8279
- Full Member
- Location: http://creativitainformaticart.altervista.org
- OrthogonalProjections.js
- (78.01 KiB) Downloaded 434 times
Re: I can't change the color of an entity
Try:
false: Don't use current attributes chosen by user.
op.addObject(entity, false);
- Full Member
ok, thanks, it works
