I can't change the color of an entity
pietro_72_
Location: http://creativitainformaticart.altervista.org
Post by pietro_72_ » Thu Dec 26, 2019 5:32 pm
Hello
I can't change the color of an entity made with QCAD Simple API
I did some tests (see around line 662 of the attached code) also taking inspiration from https://qcad.org/rsforum/viewtopic.php? ... olor#p8279
OrthogonalProjections.js
(78.01 KiB) Downloaded 29 times
Re: I can't change the color of an entity
Post by andrew » Thu Dec 26, 2019 6:21 pm
Try:
op.addObject(entity, false);
false: Don't use current attributes chosen by user.
pietro_72_
Post by pietro_72_ » Thu Dec 26, 2019 6:35 pm
ok, thanks, it works
