Hi
Is it possible to get the line number of the code in which an error occurs with the following system?
try {
catch (e) {
EAction.handleUserMessage ("");
EAction.handleUserMessage ("Start error tracking");
EAction.handleUserMessage (e.name);
EAction.handleUserMessage (e.Message);
EAction.handleUserMessage ("Error:" + e);
EAction.handleUserMessage (e.fileName);
EAction.handleUserMessage ("End tracking Error");
Get the line number of an error
- Full Member
- Location: http://creativitainformaticart.altervista.org
Re: Get the line number of an error
You could use multiple try / catch blocks to narrow down the location.
Or leave away the try / catch and let the script debugger tell you where the error is (start QCAD with -enable-script-debugger).
- Full Member
Thanks, I tried using .../qcadcam-3.20.1-pro-linux-x86_64/qcad" "-always-load-scripts" "-enable-script-debugger" "-rescan", but after the third continues the program turns off
- QCAD_debugger_Istantanea_2019-12-13_08-01-53.png (262.49 KiB) Viewed 3977 times
