Free Hatch Patterns
John Hyslop
Re: Free Hatch Patterns
Post by John Hyslop » Sat Nov 23, 2019 3:00 am
Hi All
I've added headers to all my hatch patterns the header contains this text as suggested by CVH :-)
;By John Hyslop
;Developed in inch as imperial QCAD3 pattern
Here is a fullset of all I have done so far if using Metric download the metric set.. Enjoy :-)
The Dotted Circle Hatches are made with short lines.. not the best practice but ok for representations..
Some Pattern Updates are now on Page 4 of this topic
Set of 15-Hatch-Patterns.zip
(13.25 KiB) Downloaded 90 times
15 Qcad Imperial Hatch Patterns.jpg (197.43 KiB) Viewed 2111 times
John Hyslop
Post by John Hyslop » Sat Nov 23, 2019 6:22 am
Seamless MAZE-02 Coming soon 👌
Post by CVH » Sat Nov 23, 2019 2:23 pm
Forgot the LATTICE-04 Ortho....
You can use 0 (zero) for dashes 1-6 instead of a positive number.
That would render to a dot.
Positive is the length ON.
Negative is the length OFF.
dashes 5,-3,0,-1,0,-1 would be:
bar(5long), space(3), dot, space(1), dot, space(1)
QCADpro 3.24.3.10 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
John Hyslop
Post by John Hyslop » Sun Nov 24, 2019 6:02 am
Qcad Metric Hatch Patterns
Some Updated Patterns are now on Page 4 of this topic
Set of 15-Hatch-Patterns [ METRIC ].zip
(15.19 KiB) Downloaded 82 times
Qcad Metric Hatch Patterns.jpg (205.94 KiB) Viewed 2056 times
John Hyslop
Post by John Hyslop » Sun Nov 24, 2019 6:56 am
MAZE-02 Seamless in Imperial... Metric File to Follow
MAZE-02.pat
(1.24 KiB) Downloaded 76 times
John Hyslop
MAZE-02 Seamless in Metric
MAZE-02.pat
(1.54 KiB) Downloaded 73 times
John Hyslop
Post by John Hyslop » Thu Nov 28, 2019 8:30 am
Hatch Patterns BOXJOIN-01,BOXJOIN-02,HEXJOIN-01,HEXJOIN-02
Metric & Imperial Downloads
BOXJOIN-HEXJOIN-01-02-Metric.zip
(1.33 KiB) Downloaded 76 times
BOXJOIN-HEXJOIN-01-02-Imperial.zip
(1.23 KiB) Downloaded 76 times
HEXJOIN - BOXJOIN - 01 - 02.jpg (96.59 KiB) Viewed 2008 times
John Hyslop
Post by John Hyslop » Thu Nov 28, 2019 9:07 am
LATTICE-05 & LATTICE-06
In Metric & Imperial
LATTICE-05-06-Metric.zip
(699 Bytes) Downloaded 77 times
LATTICE-05-06-Imperial.zip
(625 Bytes) Downloaded 75 times
LATTICE-05 and LATTICE-06.jpg (67.12 KiB) Viewed 2007 times
John Hyslop
Post by John Hyslop » Thu Nov 28, 2019 11:20 am
Australian REDBACK Spider
REDBACK - Metric and Imperial.zip
(4.52 KiB) Downloaded 79 times
RedBack - Spider.jpg (63.08 KiB) Viewed 2000 times
John Hyslop
Post by John Hyslop » Sat Dec 14, 2019 9:35 am
TRIANGLE & BOX OVERLAP PATTERNS in Metric & Imperial
TRI-BOX-OVERLAP - Metric.zip
(784 Bytes) Downloaded 73 times
TRI-BOX-OVERLAP - Inch.zip
(712 Bytes) Downloaded 72 times
Post by CVH » Sat Dec 14, 2019 7:11 pm
John Hyslop wrote:
Wed Nov 20, 2019 10:51 pm
LATTICE-04 [ see angle note on screenshot ] to make it orthogonal..
If you require a more accurate angle the true one is 26.565051deg :-)
And the not turncated angle would be:
ATAN2(2,1)
Do you see it John? :D
Tiles2Patterns...Closing in on it.
Cheers
John Hyslop
Post by John Hyslop » Sat Dec 14, 2019 10:06 pm
Hi CVH
I private messaged you to keep this area clear for hatch patterns..
Cheers john
John Hyslop
Post by John Hyslop » Sun Dec 15, 2019 3:57 am
SCAFFOLD PATTERN HAS BEEN UPDATED, PLEASE SEE POST DATED 11/01/20
This Pattern might be handy for builders and architects.
Note: if your drawing is scaled 1:1 Consider setting a high scale
eg. 200 then adjust it to get the approximate size..
Scaled at 200 will result in the platform sizes below:-
Metric = 2540mm Long
Inch = 100" Long
This Pattern is not intended to be an accurate way of drawing
scaffolding , it is for quick representational purposes only :-)
Metric & Imperial Files Included....
Cheers
John
SCAFFOLD-PATTERNS - mm and inch.zip
(1.45 KiB) Downloaded 68 times
John Hyslop
Post by John Hyslop » Tue Dec 17, 2019 4:41 am
Here's another 2 Hatch Patterns BLOCKS-01 & BLOCKS-02 in Metric & Inch
These could be exploded and used as garden screens cut from corten
steel " steel that naturally rusts " some of my other patterns can
be used for this purpose also eg some of the Lattice patterns.. :-)
PATTERNS - BLOCKS-01 and -02 - mm and Inch.zip
(2.38 KiB) Downloaded 69 times
BLOCKS -01 and -02.jpg (97.61 KiB) Viewed 1733 times
John Hyslop
Post by John Hyslop » Tue Dec 17, 2019 5:32 am
XMASTREE PATTERNS Metric & Imperial
PATTERNS - XMASTREE-01 and -02 - mm and inch.zip
(3.54 KiB) Downloaded 62 times
XMASTREE-01 and -02.jpg (173.24 KiB) Viewed 1731 times
