Deleting entity segfaults
Post by andrew » Fri Oct 18, 2019 8:15 am
From a QCAD user:
Why does this code segfault?
var op = new RAddObjectsOperation();
op.addObject(entity);
di.applyOperation(op);
op.deleteObject(entity);
Re: Deleting entity segfaults
Post by andrew » Fri Oct 18, 2019 8:16 am
Entity pointers should not be used more than once in an operation. If you need to apply an operation on the same entity, you need to retrieve a new pointer first:
var id = entity.getId();
entity = doc.queryEntity(id);
