reduce a button
pietro_72_
Location: http://creativitainformaticart.altervista.org
reduce a button
Post by pietro_72_ » Thu Sep 26, 2019 8:09 am
It is possible to decrease the width of a QPushButton, I tried with:
      <property name = "geometry">
       <Rect>
        <Width> 21 </ width>
        <Height> 21 </ height>
       </ Rect>
      </ Property>
but it did not work
Thank you also for the previous answer
Screenshot_20190926-085636_VNC Viewer.jpg (9.01 KiB) Viewed 999 times
Re: reduce a button
Post by andrew » Mon Sep 30, 2019 9:46 am
The button might be in a layout in which case the layout controls the button size.
You should be able to override by setting size policy to fixed:
https://doc.qt.io/qt-5/qwidget.html#siz ... e-policies
pietro_72_
Re: reduce a button
Post by pietro_72_ » Wed Oct 02, 2019 8:25 am
I tried that:
     newIdObj3D = objectFromPath ("MainWindow :: Options :: NewIdObj3D");
     //newIdObj3D.resize(21,21);
     sizePolicy = QtGui.QSizePolicy (QtGui.QSizePolicy.Fixed, QtGui.QSizePolicy.Fixed);
     newIdObj3D.setSizePolicy (sizePolicy);
     newIdObj3D.clicked.connect (function () {presNewIdObj3D ();});
but am I probably wrong?
Re: reduce a button
Post by andrew » Wed Oct 02, 2019 6:51 pm
Please have a look at PropertyEditor.js for an example to set the size policy.
Note that you can search the git repository online (for example for "QSizePolicy .js"). Or you can checkout the repository and search locally. QCAD sources contain lots of JS code with plenty of example code.
pietro_72_
Re: reduce a button
Post by pietro_72_ » Wed Oct 02, 2019 9:46 pm
ok thank you, I try to arrange myself as much as possible :D
solved this way:
    <Item>
     <widget class = "QPushButton" name = "NewIdObj3D">
      <property name = "toolTip">
       <string> Creates a new 3d shape </string>
      </ Property>
    <property name = "sizePolicy">
     <sizepolicy hsizetype = "Maximum" vsizetype = "Fixed">
      <Horstretch> 0 </ horstretch>
      <Verstretch> 0 </ verstretch>
     </ Sizepolicy>
    </ Property>
    <property name = "maximumSize">
     <Size>
      <Height> 16777215 </ height>
     </ Size>
    </ Property>
      <property name = "text">
       <String> + </ string>
      </ Property>
     </ Widget>
    </ Item>
