Widgets Get/Set value vs text
Post by CVH » Fri Sep 20, 2019 8:22 am
What is the difference in essence between:
widgets["AnyProp"].text = xyz ;
widgets["AnyProp"].setValue(xyz);
var xyz = widgets["AnyProp"].text;
var xyz = widgets["AnyProp"].getValue();
greatly appreciated,
QCADpro 3.24.3.0 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
Re: Widgets Get/Set value vs text
Post by andrew » Fri Sep 20, 2019 9:05 am
This is Qt API for QLineEdit and string based, e.g. widgets["AnyProp"].text = "1/6".
This is QCAD API for RMathLineEdit and number based: widgets["AnyProp"].setValue(1/6);
The same is true for retrieving the value. text will give you the string (e.g. "1/6"), while getValue() will give you the value (0.166666666..).
Post by CVH » Fri Sep 20, 2019 9:39 am
Got it. :wink:
Besides that, Javascript will treat strings that represent real numbers as numbers except with additions.
And RMathLineEdit works with fixed precision 6. :(
