Updated beta 0.41 FlexPainter beta 0.34
pietro_72_
Location: http://creativitainformaticart.altervista.org
Re: Updated beta 0.41 FlexPainter beta 0.34
Post by pietro_72_ » Tue Oct 15, 2019 6:47 am
Hi, when I have time I would like to try your program, but to work it must be extracted all the content of the zip in the path
QCAD\scripts\Misc\Examples\MathExamples\
Does it work if I put your program files in a [Flexpainte] folder?
Post by CVH » Tue Oct 15, 2019 7:04 am
No,
FlexPainter is what I think is called an AddOn.
The Qcad folder structure is necessary.
Qcad expects FlexPainter.js to be in a sub folder FlexPainter.
As it originated as a Math example this has to be a sub folder of MathExamples.
QCADpro 3.23.0.0 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
pietro_72_
Post by pietro_72_ » Wed Oct 16, 2019 9:00 pm
Beautiful, strong, complex your program
I don't use these forms much, but you never know
If in case I could also take inspiration from your code if you don't mind?
Good job.
Post by CVH » Thu Oct 17, 2019 12:17 am
Thanks,
Me neither, :wink:
No I don't mind.
As it is already part of the lastest Qcad snapshot, its free to use.
As always we have to read the fine print.
I hope my documented struggles at least inspire others in scripting.
My knowledge of QT, Javascript or the Qcad project was non-existent.
What if we used the base-line to cast:
> pebble stones under it, sand, asfalt
> gras above it
(Width = depth or height)
PS: :?
Writing this reply remembered to include
reference to OrthogonalProjections.js Topic
Revision Clouds by FlexPainter
Post by CVH » Fri Oct 18, 2019 9:53 am
In respons to:
https://qcad.org/rsforum/viewtopic.php?t=6131
https://qcad.org/rsforum/viewtopic.php?t=3519
https://qcad.org/rsforum/viewtopic.php?t=846
Coded some clouds painters.
Will be included in a next release.
Regards.
RevisionCloudTest.dxf
(133.63 KiB) Downloaded 32 times
