Can't find the correct syntax in scripting
Post by CVH » Sat Aug 03, 2019 7:43 pm
Andrew, I am missing out on the syntax in scripting
I got two similar ones I can't get to work.
with entity = document.queryEntity(id);
with isArcEntity(entity) = true
How to properly address
math...Rarc...isFullCircle as Boolean
with isPolylineEntity(entity) = true
math...RPolyline...bulges as Qlist
math...RPolyline...getBulges as Qlist
math...RPolyline...hasArcSegments as Boolean
And/or what to explicitly include?
Compiled there are fairly no scripts present as file.
(Plain Wininstaller)
Regards
Re: Can't find the correct syntax in scripting
Post by andrew » Sun Aug 04, 2019 9:53 pm
var arcShape = entity.castToShape();
if (arcShape.isFullCircle()) {
var plShape = entity.castToShape();
var bulges = plShape.getBulges();
if (plShape.hasArcSegments()) {
You might want to search our github repository or download the scripts as sources:
https://github.com/qcad/qcad
Post by CVH » Mon Aug 05, 2019 6:03 am
Thanks Andrew,
I found the 'shape method' myself but it solves not all of my concerns.
Looking at a shape signature
eg
[code]RArc(RShape(address: "0x15d2a2b0"), center: RVector(56.2438, -22.9758,.....[/code]
Does Qcad rely on the turncated numbers or on the underlying full precision?
I have a copy of the scripts as source for reference.
Not allways the latest but its only to peek at.
The script folder under Win/Progarms is as it comes, fairly empty, and is kept so.
For numberToString() I had to add sprint.js because this trows an error without.
Post by andrew » Tue Aug 06, 2019 9:24 am
Does Qcad rely on the turncated numbers?
No, that's just the output of the object's toString() method.
