Hello all,
I think it's not possible right now restrict orthogonal in angles different to X,Y axis. I was trying to create a script that restricts orthogonal but relative to one particular selected entity. I'm working on:
RestrictOrthogonal.js
RestrictOrthogonalInit.js
RRestrictOrthogonal.cpp
RRestrictOrthogonal.h
Any suggestion about that? Do you think it is difficult to manage? Thanks!
Restrict Orthogonal Relative to Entity's Angle
Re: Restrict Orthogonal Relative to Entity's Angle
You'd have to allow the user to pick an entity when the restriction tool is started, then base the restriction on that entity. Also, there'd probably have to be a way to change that base entity somehow and choose a new one...
