Can scripts output to a text file?
JSRoy
Post by JSRoy » Fri Feb 22, 2019 10:55 pm
Hi all,
I am developing a script to draw lines. When I run my script, qCad is not drawing what I am expecting.
I would like to review all values I am using in my script when calling addLine(). Is there a way for me to create a text file and output my data into it? I have over 700 points, so having a text file would make it easier to review my data and find out what is wrong.
Jean-Sebastien Roy
RR88
Re: Can scripts output to a text file?
Post by RR88 » Fri Feb 22, 2019 11:50 pm
Gentoo/Linux, QCad 3.20 Prof.
JSRoy
Post by JSRoy » Sat Feb 23, 2019 2:57 am
Thank you RR88,
With your help I managed to figure out my problem. The Math.sin() function expect an angle expressed as a radiant. I was giving it an angle in degrees.
Would you know where to find the Math class in the document? I found RMath, but no mentions of Math.
Thank you,
Jean-Sebastien Roy
Post by andrew » Sat Feb 23, 2019 10:29 am
Note that Math is part of the JavaScript API, not QCAD:
https://www.w3schools.com/js/js_math.asp
RR88
Post by RR88 » Sat Feb 23, 2019 5:20 pm
Math.sin(angle*Math.PI/180)
:P
