Question on the script generator from a curious guy!
neFAST
Post by neFAST » Tue Jan 08, 2019 10:45 pm
I just discovered QCad from a friend and it looks like a solid and great piece of software!
I was looking at the console and the fact that Qt Object are wrapped in the ECMA engine.
From what I understand, old Qt owners (trolltech) used to distribute a qt-script-generator responsible for creating the project that are committed under https://github.com/qcad/qcad/tree/master/src/3rdparty
Is it how where those "generated_cpp" comes from? Is the script-generator commited anywhere else?
Thanks in advance for your help!
Regards
nF
neFAST
Re: Question on the script generator from a curious guy!
Post by neFAST » Thu May 30, 2019 7:54 am
Is that a sensitive/tough topic?
Post by andrew » Thu May 30, 2019 10:13 am
Yes.
Not that I'd know.
No, just not very relevant for the vast majority of QCAD users / developers ;)
neFAST
Post by neFAST » Fri May 31, 2019 9:12 am
Thanks a lot for your reply.
I can imagine most of QCAD users don't care.
Reason I asked is that I had played with the qtscriptgenerator and Qt4 a while back, and when moving to Qt5 projects I hard a hard time trying to compile it.
I had found this phbaer guy who forked the repository from shibukawa, but still I could manage to make it work with my Qt5 setup.
Post by andrew » Wed Jun 05, 2019 10:19 pm
You can find the Qt script bindings we're using for QCAD under:
neFAST
Post by neFAST » Tue Jun 11, 2019 8:07 am
Hello Andrew. I foudn the QtScript bindings but I was wondering which qt-script-generator generated those projects.
Last time I tried the fork from shibukawa it would not properly run with Qt5.7+
