Create .txt file
pmbrull
Create .txt file
Post by pmbrull » Mon Oct 15, 2018 11:19 am
Hello and thank you for your time,
I am trying to create a txt file with some results calculated inside a script. I was following this discussion:https://www.qcad.org/rsforum/viewtopic. ... +txt#p1788
    include("scripts/File/File.js")
    var file = new File("file.txt");
    file.open(File.WriteOnly);
    file.writeLine("hello");
    file.close();
And I get a constructor error: Wrong number/types of arguments for RAction.setGuiAction(), which makes sense because in the docs File gets a void Gui Action.
Is there any way to save some results?
Thank you,
Pere
Re: Create .txt file
Post by andrew » Mon Oct 15, 2018 11:32 am
That thread refers to QCAD 2 with its QSA script interface (obsolete).
Our github repository is a good source for current / up to date scripts:
https://github.com/qcad/qcad/tree/master/scripts
Or the scripts/Misc/Examples folder of your QCAD installation. For example scripts/Misc/Examples/IOExamples/ExRegisterFileExporter/ExRegisterFileExporter.js
pmbrull
Post by pmbrull » Mon Oct 15, 2018 11:41 am
Thanks for the guidance,
works like a charm.
Pere,
