checking if two polygons touch each other
sarlaa
Post by sarlaa » Fri May 25, 2018 5:24 pm
I need to know if two polygon shapes touch each other.
You showed me how to use RPolygonClipper with union mode (RS.Union) :
var clipper = new RPolygonClipper();
// add subject paths (islands: ccw, holes: cw):
clipper.addSubjectPath([new RVector(0,0), new RVector(100,0), new RVector(100,100), new RVector(0,100)]);
clipper.addSubjectPath([new RVector(50,50), new RVector(150,50), new RVector(150,150), new RVector(50,150)]);
// union:
clipper.execute(RS.Union, RS.NonZero);
// print result:
for (var c=0; c<clipper.getSolutionPathCount(); c++) {
    var vertices = clipper.getSolutionPath(c);
    qDebug("polygon:", vertices);
So I'm thinking to use RPolygonClipper with intersection mode if exists ?
And I can check if results points are on the same line.
could you show me if it exists how ?
Thanks !
Re: checking if two polygons touch each other
Post by andrew » Fri May 25, 2018 7:19 pm
You can find the intersection points between two polylines using getIntersectionPoints:
var pl1 = new RPolyline();
pl1.setVertices([new RVector(0,0), new RVector(100,0), new RVector(100,100)]);
var pl2 = pl1.copy();
pl2.move(new RVector(10,10));
var ips = pl1.getIntersectionPoints(pl2);
qDebug(ips);
Output:
RVector(100, 10, 0, true)
