Check if three points ([RVector]) are aligned
miro
Post by miro » Fri Dec 29, 2017 7:21 pm
Could you tell me how can I check programatically if three points ([RVector]) are aligned.
I tried :
 var pointsCheck = [pointStart, pointEnd, pointsIntersec[0]]
  var polyline = new RPolyline(pointsCheck, false)
  var isAlign = RShape.isXLineShape(polyline);
  EAction.handleUserMessage("pointsCheck : " + pointsCheck)
  EAction.handleUserMessage("isAlign : " + isAlign)
But this way doesn't work for me.
Many thanks
Miro
Re: Check if three points ([RVector]) are aligned
Post by andrew » Fri Jan 05, 2018 12:13 am
You could create a line from two points and then check if the third point is on the line using isOnShape:
if (new RLine(p1, p2).isOnShape(p3, false)) { ... }
miro
Post by miro » Mon Jan 08, 2018 6:38 pm
Thanks it works !
