My question is about persistence of Entity Id :
I have a Transaction listener that is installed at qcad start-up, for showing entity line Id when it's affected.
And I do this scenario :
I draw a Line base on tool Line2P, and I see through the listener, that the line entity have 47 as Id (screen1).
Whatever change I make on the line after that I keep seeing the same Id 47 (screen2).
I save the document with name myTestObjId, I close qcad.
And I open this my document myTestObjId, now I see onother Id for my line : 48 !! (screen3)
If Entity Id, isn't persistent after save, what information is persistent after save ?
(I join screenshots that shows the scenario described with the results)
Thanks in advance !
Entity Id change after save
- screen1.PNG (68.79 KiB) Viewed 5482 times
- screen2.PNG (77.07 KiB) Viewed 5482 times
- screen3.PNG (67.36 KiB) Viewed 5482 times
Re: Entity Id change after save
Object IDs are not persistent.
Object handles should be used if a persistent reference to an object is needed.
RObject::getHandle();
Thanks for responding, but still I have the same issue using handles :
Before I save the document my object handle is 47.
And after I save the document and I reopen it, handle of object changed to 89.
I need to have something persistent after save and reopening.
Thanks again !
Thanks again !
I just saw that you are using dxflib to write the file.
I should have mentioned that handles are only persistent using the QCAD Professional Teigha based filters for exporting / importing DXF/DWG.
