Do you always need to restart QCAD to test scripts?
pietro_72_
Location: http://creativitainformaticart.altervista.org
Post by pietro_72_ » Sun Jul 30, 2017 5:06 pm
Ciao a tutti
Ho la versione 3.16.7.0 (3.16.7) di QCAD
Per testare gli script in ECMAScript dopo le modifiche è sempre necessario riavviare QCAD o ora c'è un altro modo?
Translation by google
Hello to all
I have QCAD version 3.16.7.0 (3.16.7)
To test the scripts in ECMAScript after the changes you always have to restart QCAD or is there another way now?
hungerburg
Re: Do you always need to restart QCAD to test scripts?
Post by hungerburg » Sun Aug 06, 2017 2:54 pm
Does -always-load-scripts (still) not work for you?
pietro_72_
Post by pietro_72_ » Tue Aug 08, 2017 7:02 am
Thank you
it works
I did QCAD in 2 ways:
"...... \ qcad.exe" "-always-load-scripts" "-enable-script-debugger" "-rescan" // to find bugs
is
"....... \ qcad.exe" // running normally without debugger
I did not realize that it was missing from the latter "-always-load-scripts"
pietro_72_
Post by pietro_72_ » Wed Aug 22, 2018 10:06 am
Su Ubuntu 18.04.1 LTS 64 bit -always-load-scripts non funziona
deepl translation
On Ubuntu 18.04.1 LTS 64 bit -always-load-scripts does not work
results on Terminal:
[email protected]:~$ "/home/pietro/opt/qcadcam-3.20.1-pro-linux-x86_64/qcad" "-always-load-scripts"
QCAD version 3.20.1
10:49:33: Debug: RCamScriptsPlugin::init
10:49:33: Debug: RCsgPlugin::init
10:49:33: Debug: RDwgPlugin::init
10:49:33: Debug: RDxfPlugin::init
10:49:33: Debug: RGLES3DPlugin::init
10:49:33: Debug: RHelpPlugin::init
10:49:33: Debug: RPolygonPlugin::init
10:49:33: Debug: RProScriptsPlugin::init
10:49:33: Debug: RScriptsPlugin::init
10:49:33: Debug: RTriangulationPlugin::init
10:49:33: Debug: RGLES3DPlugin::initScriptExtensions
Warning: action not found: ":scripts/Reset/Reset.js"
Warning: action not found: ":scripts/File/File.js"
Warning: action not found: ":scripts/File/AutoSave/AutoSave.js"
Warning: action not found: ":scripts/File/BitmapExport/BitmapExport.js"
Warning: action not found: ":scripts/File/CloseFile/CloseFile.js"
Warning: action not found: ":scripts/File/ImportFile/ImportFile.js"
lePath: :scripts/Help/ReportBug/ReportBug.js),AddOn(actionText: '', groupName: Help, filePath: :scripts/Help/ReportTranslationError/ReportTranslationError.js),AddOn(actionText: '', groupName: Help, filePath: :scripts/Help/ShowReadme/ShowReadme.js),AddOn(actionText: '', groupName: Help, filePath: :scripts/Help/Website/Website.js), splash = QSplashScreen) at :scripts/autostart.js:365\nmain() at :scripts/autostart.js:664\n<global>() at :scripts/autostart.js:788"
10:49:34: Debug: "<global>() at 26"
QCAD has unexpectedly quit.
Please use the offscreen platform plugin for headless systems
(without a running X11 server):
/home/pietro/opt/qcadcam-3.20.1-pro-linux-x86_64/qcad -platform offscreen
In addition, you might have to override the default Qt style
to prevent the loading of a native desktop style (such as GTK):
/home/pietro/opt/qcadcam-3.20.1-pro-linux-x86_64/qcad -style plastique
Post by andrew » Wed Aug 22, 2018 10:13 am
Please try 3.21.2 if possible.
pietro_72_
Post by pietro_72_ » Wed Aug 22, 2018 10:57 am
thank you, I will try
