Right Click Context Menu
cjh
Post by cjh » Thu Oct 13, 2016 8:51 pm
How do I add an action to the right click context menu?
If I right click a block, the "Edit Block" action is an option.
Where is that context menu defined?
I would like to add custom actions to the right click block context menu.
Connor
Re: Right Click Context Menu
Post by Husky » Fri Oct 14, 2016 6:54 pm
Hi Connor,
cjh wrote:I would like to add custom actions to the right click block context menu.
unfortunately the context menu isn't adjustable and in my opinion why it should be? It's a context menu ...
However, I'm curious: What kind of tools would you like to add to the menu?
cjh
Post by cjh » Fri Oct 14, 2016 7:19 pm
The right-click context menu already shows different options for different entities, so that adjustment has to occur somewhere!
I just can't trace it beyond when the RMainWindowQt emits contextmenu((int)entityId, pos) signal.
If you right click a block, the context menu gives an Edit Block option at the bottom.
If you right click a line, you have the options to Deselect Contour and Auto Create Polyline.
I would like to right click a block and have the option to run a custom action to "Assign Parts" to the block.
It will show a dialog to assign custom properties to the block by pulling part list info from a database.
Using these custom properties, I can auto-create a bill of materials to appear on the drawing.
Post by andrew » Fri Oct 14, 2016 7:39 pm
It's not possible to extend the context menu in the current version.
However, you can replace it with your own:
MyContextMenu.js:
include("scripts/Pro/Widgets/ContextMenu/ContextMenu.js");
function MyContextMenu() {
MyContextMenu.init = function(basePath) {
    var appWin = RMainWindowQt.getMainWindow();
    // register (connect context menu):
    appWin.contextMenu.connect(MyContextMenu, "showEntityContextMenu");
MyContextMenu.postInit = function() {
    // disconnect (disable) current context menu:
    ContextMenu.disconnect();
// This is called when the user right-clicks an entity
MyContextMenu.showEntityContextMenu = function(entityId) {
    var doc = EAction.getDocument();
    var entity = doc.queryEntity(entityId);
    var menu = new QMenu(RMainWindowQt.getMainWindow());
    menu.exec(QCursor.pos());
I've also refactored ContextMenu for the next release, so you can get and extend the QCAD standard context menu:
var menu = ContextMenu.getContextMenu(entityId);
cjh
Post by cjh » Fri Oct 14, 2016 7:46 pm
Ahhh that's why I couldn't find it!
I'll wait for the next release before working with it.
Thanks Andrew!
