how to set the size of view
liguosheng
Post by liguosheng » Thu Jan 14, 2016 4:23 am
when i create a new null document, the view is small, how can i set it?
Re: how to set the size of view
Post by andrew » Thu Jan 14, 2016 9:01 am
Please elaborate.
- What is a 'null' document'?
- What do you mean by the 'size' of a document?
Moderator / Drawing Help
Post by Clive » Thu Jan 14, 2016 12:00 pm
Andrew, I think maybe 'Null' means empty ?
hungerburg
Post by hungerburg » Thu Jan 14, 2016 8:17 pm
I guess I got it: Its about the initial zoom. Attached screen-shot of what I get; Unit is mm, so display is larger than life. I always have to zoom out first, because my stuff usually is around 1m big. As I always print scaled, font-size is 24mm.
unit mm
liguosheng
Post by liguosheng » Sat Jan 16, 2016 1:47 pm
thanks! problem is solved.
