Hi again,
after having resolved some obstacles between Windows and Unix / cygwin, and having all evironment set up for msvc2010, my build of QT in debug-version went ok. Trying to build QCad (from 4.7.6-zip) led to following problem:
qmake -r stops because a plugin plugins/designer/qwebview.dll is missing. As I built Qt for debug, I only have a qwebviewd.dll ....
Is this a little mistake in the .pro-Files?
As a workaround, i am building Qt now with -debug-and-release. Think this will create the missing release-plugin.
Ulrich
build qcad with Qt built for debug
Re: build qcad with Qt built for debug
There's something special about qwebview... IMHO, Qt should take care of the 'd' though.
Personally, I've never linked against Qt in debug mode under Windows as I only do Windows releases on Windows and prefer to develop on other platforms. So it's perfectly possible that something would have to be adjusted to make this work.
