[solved] QTableView Question
333onlyhalfevil
Post by 333onlyhalfevil » Sat Apr 13, 2024 6:12 am
I'm having some trouble getting a QTableView to work how I want it to in one of my scripts. I made one in the Qt designer in the *.ui file then edited it with the following code:
var model = new QStandardItemModel(4,6);
var tableView = widgets1["testList"];
tableView.setModel(model);
tableView.verticalHeader().setVisible(false);
which all works as expected. However, I can't seem to get it past this. Everything I try to do after this causes the script to fail, typically with an error where it can't find something.
I tried editing the header with this code:
var header = new QStringList("header1");
header.append("header2");
header.append("header3");
header.append("header4");
header.append("header5");
header.append("header6");
tableView.setHorizontalHeaderLabels(header);
with no luck.
I tried editing a single column header with this:
tableView.setHeaderData(2, Qt.Horizontal, "test");
with no luck.
I tried editing the data within the table with this:
for (var row = 0; row < 4; row++) {
        for (var col = 0; col < 2; col++) {
            var index = new QModelIndex(row, col);
            model.index(index);
            model.setData(index, 0);
with no luck.
Even something as simple as
var test = new QString("test");
fails. It's weird that this line (and the others) wouldn't work as expected but the QStandardItemModel at the top works fine.
What do you think? What am I doing wrong? Thank you very much for your time.
333onlyhalfevil
Re: QTableView Question
Post by 333onlyhalfevil » Sat Apr 13, 2024 4:48 pm
Nevermind. Figured it out. Thanks anyways. Needed to be doing it with QStandardItem and then setting it to the appropriate position within the QStandardItemModel. Note that each cell needs its own unique QStandardItem and multiple cells can't reference the same one.
Post by andrew » Mon Apr 15, 2024 9:37 am
For the sake of a complete answer for anyone reading this:
There are no QString or QStringList classes in the script environment.
Instead of
use
var test = "test";
Instead of
use
var header = ["header1", "header2", ...];
Re: [solved] QTableView Question
Post by CVH » Mon Apr 15, 2024 2:36 pm
use
Or use
var header = [];
header.push("header1");
header.push("header2");
